I've got a set of 17" x 7.5" rims (decent 3 piece alloys) and am thinking about refurbishing them and fitting them to the Kizashi. 235/50R17 would be my preferable tyre size if I go ahead fitting them.
The overall diameter is virtually identical to the stock 215/55R17, but the width matches the 18" tyre spec.
Has anyone tried 235/50R17 tyres?
I'm not 100% sure what the offset of them is, but they were custom made to suit a Mazda 6 so it shouldn't be a problem. The only issue I may have is the hub centre bore being a different diameter?
I'll try test fitting one sometime (they're fitted with 225/45R17 tyres at the moment.) I might have to buy some wheel nuts first though as they require the small diameter "tuner style" nuts from memory.
