how much rear wheel camber??
The Kizashi has a lot of newly engineered components which will undoubtedly have some issues. Please let people know what problems you are experiencing. Ask technical questions related to the Kizashi under this topic.
PostPosted: Sat Jul 31, 2010 5:19 pm
How much negative camber is normal on the AWD. I walked out of the house yesterday and happened to notice what looked like the top of the rear wheels tipping in quite a bit. I thought it might be an optical illusion but did dirt check, by dirtying the tires and measuring the clean patch on the outside I get about 1 1/2 inches of clean rubber. This will most certainly wear the insides of the (not cheap) tires out. Just wondering if my alignment is out or are they all this way. thanks
PostPosted: Sun Aug 01, 2010 2:36 am
Check the owners manual.
PostPosted: Sun Aug 01, 2010 4:56 am
Thanks, checked manual but does not specify rear. with 16 views I thought someone would look at theirs. It is really obvious looking at it from the rear. I can actually shine a flashlight under the outside 1"-1.5" inch or so of the tire where it does not hit the ground. Any feedback greatly appreciated. On a positive note i hit 750 miles and my mpg is definitely going up.
PostPosted: Mon Aug 02, 2010 3:24 pm
I'll take a look later today and let you know.
Moderator
6 speed
Past Cars:
2008 Subaru Legacy 2.5i
1998 Audi A4 1.8TQM
1998 Dodge Avenger ES
PostPosted: Tue Aug 03, 2010 2:21 pm
I just checked mine with a carpenter lever, and both front and rear are slightly tipped in (not really noticeable - that is why I used the level). It sounds like yours is way off. I would think a trip to Suzuki service is in order, as it must have been delivered this way so they should do an alignment for you.
We would all be interested if you do take it in to see what the settings should be. If slight negative camber is routine for both front and rear, then we would know what to look out for.
PostPosted: Tue Aug 03, 2010 5:05 pm
thanks gaww, i checked mine with a pitch-angle level and get around 3-4 degrees negative camber on rear only , both sides though.
PostPosted: Wed Aug 04, 2010 9:14 pm
What we need now are specs.
There was a posting on here with some of the service manual sections - going to look to see if they are in any of them.
PS - not in there.
I tried to order the specs from the source of the posting info, but their webpage (http://suzukipitstopplus.com/) seems to be screwed up.
PostPosted: Thu Aug 05, 2010 1:44 am
I contacted my nearest dealer for the specs which i did not get but they want to look at it friday and put on machine to verify. i will try to get print out for my records.
PostPosted: Fri Aug 06, 2010 7:10 pm
GREG wrote:I contacted my nearest dealer for the specs which i did not get but they want to look at it friday and put on machine to verify. i will try to get print out for my records.
Any update ?
PostPosted: Fri Aug 06, 2010 10:58 pm
The guy at the dealer knows it all and said i was wasting my time that it is the way it it is for handling and to wait till the first rotation to see if there is any abnormal wear. still couldn't get any numbers from them so i went to a friends repair shop where their alignment computer was just updated and got the specs. Rear camber is -.8 min to -1.8 max front is -.5 to-1.5. all i can say is my rear is way more than the front and i don't believe they are in spec. even if they are in spec they will sure as hell wear tires early. bottom line; my friend at the shop will hook me up with specs that work for him on most vehicles to save the tires and get a little better mileage.
Next
Return to Kizashi Technical Support
Who is online
Users browsing this forum: No registered users and 1 guest
