Brake service
KIZFAN2
Brake service
Post#1 » Mon Jun 03, 2013 3:48 pm
Just noticed this week during my oil change that I have not serviced the brakes in over 40,000 kms.
Has anyone serviced the breaks on the kizashi's yet? If not, what are the repercussions?
2011 Kizashi SX
Re: Breaks service
Post#2 » Tue Jun 04, 2013 2:56 am
Not to be an ass, but it's spelled brakes. Most people would not want their brakes to "break". ;)
Also, the lifespan of brakes really depends on your driving style and conditions.
If you live on a mountain and/or are an aggressive driver (accelerate and brake quickly) then your brakes will wear out faster and you will be replacing your brake pads and rotors more frequently. If you live in a rural area or even the suburbs with mostly highways and little traffic, your brake pads will last much longer.
Brakes are similar to clutch discs and that driving style is the key factor to their longevity. They both eventually wear out and are designed to be replaced. Aggressive driving simply results is these components lasting a shorter amount of time. My Kizashi only has 15,000 miles on it so my brakes are still good.
Re: Breaks service
Post#3 » Tue Jun 04, 2013 11:02 am
I'm used to getting 50K miles/80K kilometers out of my brakes, but that's with the way I drive and previous cars, we'll see if the Kizashi stacks up similarly. Also, I always have a manual transmission, automatics are a bit harder on the brakes.
Want an alternative to big government presidential candidates? http://www.GaryJohnson2016.com
2010 Kizashi GTS manual
1991 Pontiac Firefly Turbo
KIZFAN2
Re: Brake service
Post#4 » Tue Jun 04, 2013 3:49 pm
Fixed breaks to brakes - stupid iPhone (didn't notice until you pointed it out).
Suzuki recommended that I service my brakes every 25,000 km. It includes lubing/adjusting the calipers and removing the pad glaze. They said it will help with the life extension of the brakes in general.
2011 Kizashi SX
puckaveli
Re: Brake service
Post#5 » Tue Jun 04, 2013 6:46 pm
Just check your pad thickness. If you don't have any pedal pulse then your rotors are probably good. Unless you constantly ride your brakes you won't have enough glazing to cause any issues. If you don't see any fluid leaking from the caliper then most likely won't need any adjusments.
2000 Subaru Impreza 2.5RS
2013 Suzuki Kizashi GTS AWD
2006 Kawaski 636
Re: Brake service
Post#6 » Wed Jun 05, 2013 12:45 pm
See my 114 days thread; I just replaced my rears at 85,500..........
..............and I drive like an insane adolescent...........
KIZFAN2
Re: Brake service
Post#7 » Wed Jun 05, 2013 2:55 pm
I agree, I don't think there is any need to service the brakes at this point. Especially at $175 to do so.
Just hit 75,000 km and I still have 6mm of pad left on both the front and rear.
2011 Kizashi SX
nytq
Re: Brake service
Post#8 » Sun Jun 16, 2013 2:07 pm
Just found these on tirerack
Very reasonable for Akebono
Akebono Euro Ceramic Pads (Premium)
Front Fitment
Material: Ceramic
Note: Front brake pads.
Price: $64.00 (axle set) Special
Estimated Availability: Fewer than 2, Special Order Available
Manufacturer Part #: ASP1338
Qty:
1 2 3 4 5 6 7 8
Add To Cart Shipping
Quote Add to
Wish List
Additional Product Information
Overview | Reviews
Akebono Performance Pads (Premium)
Rear Fitment
Material: Ceramic
Note: Rear brake pads.
Price: $67.00 (axle set)
$57.00 Special
Estimated Availability: In Stock
Manufacturer Part #: ASP537
Qty:
1 2 3 4 5 6 7 8
Quote Add to
Wish List
Overview | Reviews
Akebono ProACT Ceramic Pads (Premium)
Front Fitment
Material: Ceramic
Price: $72.00 (axle set)
$57.00 Special
Manufacturer Part #: ACT1338
Qty:
1 2 3 4 5 6 7 8
Quote Add to
Wish List
Overview | Reviews
Rear Fitment
Material: Ceramic
Price: $47.00 (axle set)
$40.00 Special
Manufacturer Part #: ACT537
Qty:
1 2 3 4 5 6 7 8
Add To Cart
KIZFAN2
Re: Brake service
Post#9 » Tue Jun 18, 2013 2:23 pm
awesome! thanks nytq
2011 Kizashi SX
kizashijayy
Re: Brake service
Post#10 » Tue Oct 22, 2013 5:45 pm
Is it possible that after only 20k miles I need to replace the rear brakes? The guy tried to tell me the rear pads come with less padding than the fronts. Don't know if that's really the case but I don't drive very aggressively so to have to change them already is annoying. ESP when I was quoted around 270 not sure if that's including labor though.
Return to “Kizashi Technical Support & Problem Troubleshooting”
Who is online
Users browsing this forum: No registered users and 1 guest
cron
