I have been been trying to get recorded music to play and have run out of ideas. Maybe someone can help?
I have a Sandisk Sansa clip (8Gig). When I insert it I get an error 4 message. That apparently is more than 500 miliwatt and therefor the MP3 will not play. Any ideas?
The other issue, is if I use a thumb drive I CAN get the music to play, but cannot figure out how to separate the albums by genre (rock, jazz, etc). I have each album in a folder on the thumb drive by genre but all I am able to do is switch between albums. And that is a pain, especially if there are a lot of albums across various genres. Of course, maybe that is the way it is, and if so I can deal with it, but it sure would be better if I can separate the music. ???
Questions about USB/MP3
Manual says under 4GB so your 8GB stick is probably just to big. A few people have managed to get bigger drives to sort of work.
http://kizashiclub.com/forum/viewtopic.php?f=12&t=385 you should read through this if you haven't already.
Thanks for the reply, must have missed that thread. Will consider purchasing a smaller mp3. As I can get the thumb drive to work, if I could just get it to show me genre's so I can narrow down the types of music I would like to hear, I probably would forgo the mp3 player. Thanks again.
Thanks Lookin...but I THINK I did that. For example I have two folders on the thumb drive Rock & Jazz with a few (at this time) albums within each folder. When I go to the car and plug the thumb drive in and select 'folders' it does not show Rock or Jazz so I could scroll down to whatever album I want to hear. All that does happen is that I can go from one to another album across either Rock or Jazz. Maybe that is the way it is supposed to be, if so I will live with it (and maybe get a smaller mp3 player).
- TheHolyGhost
Yea, I don't think it handles nested folders, unfortunately.
6 speed
Past Cars:
2008 Subaru Legacy 2.5i
1998 Audi A4 1.8TQM
1998 Dodge Avenger ES
6 speed
Past Cars:
1998 Audi A4 1.8TQM
I have a 8gb hp flash drive that I use, I have some of my music on here... I normally have a 120gb Zune... which I can't play Suzuki... NOT everyone has an IPOD... YOu need to make an AUX Input jack.... that we can purchase and install... and NOT an FM modulator!!!!! But when I play music off my Flash Drive, I just hit random... till it jsut says random... not random f... I believe thats what it is.. but the one random just plays what is in that "folder" and when you do random.. that shuffles thru the entire memory on the drive....
This pic shows and says that you can listen to a Zune...Sarahlu03 wrote:...I normally have a 120gb Zune... which I can't play Suzuki....
http://consumerguideauto.howstuffworks. ... ior#toptab
2005 Pontiac GTO - 375 rwhp
