TPMS service?
Senegal
TPMS service?
Post#1 » Sun Oct 24, 2010 3:30 am
so 2 weeks back i filled up the tires to 38psi when the TPMS warned me about low pressure. Since then, i have gotten the alert periodically to service the TPMS, it comes and goes...am i the only one? any suggestions?
gaww
Re: TPMS service?
Post#2 » Sun Oct 24, 2010 2:36 pm
If you did the tire pressure at 38 when they were warm, they could be up to 4 pounds lower when cold. Check before driving on a cold morning.
jensmarc
Re: TPMS service?
Post#3 » Fri Nov 12, 2010 2:09 am
We must find a way to bypass that tire pressure warning. I have never had to have a car tell me when my tire is a pound off. So don't give me a dangerously distracting flashing yellow light in my face while I am half way through a 500 mile drive along an interstate at night with no air pressure pumps in sight. I paid a lot for this car and I don't want this feature so why should I have to keep it?
mapeterson2
Re: TPMS service?
Post#4 » Fri Nov 12, 2010 6:16 am
^^ Get it tuned out.
2005 Pontiac GTO - 375 rwhp
jensmarc
Re: TPMS service?
Post#5 » Fri Nov 12, 2010 3:25 pm
Can the dealer do this or is he not allowed to do it?
mapeterson2
Re: TPMS service?
Post#6 » Fri Nov 12, 2010 5:08 pm
No, dealer cannot.
jensmarc
Re: TPMS service?
Post#7 » Fri Nov 12, 2010 5:26 pm
So, can you tell me who can program it out?
mapeterson2
Re: TPMS service?
Post#8 » Fri Nov 12, 2010 6:08 pm
You'd have to find someone that can do either dyno tunes or someone that can tune Suzuki's. Try contacting Road///Race. They might be able to point you in the right direction.
TObject
Re: TPMS service?
Post#9 » Fri Nov 12, 2010 11:58 pm
I think I can disambiguate a little bit, as I had a flat tire on freeway just this morning.
When the tire pressure is low, the system advises just that: low tire pressure. According to my experiments that happens when the pressure falls below ~32 PSI.
Now, the “Service TPMS” alert comes up when there is actually something wrong with the system, such as when the system can't get the signal from one of the sensors. When I replaced the flat with the temporary spare, and placed the disabled tire in the trunk, where it was not spinning, my low tire pressure warning got replaced with the service TPMS warning after a few miles of driving on the spare.
Once the flat tire was patched up and put back on, the system got green (or should I say gray) just after a couple of minutes of driving.
redmed
Re: TPMS service?
Post#10 » Sun Sep 11, 2011 12:42 am
I have read on other forums that people are putting all four sensors inside a wheelbarrow tire. Then pumping the wheelbarrow tire & sensors up to 40 lbs and throwing into the trunk. Regular stems on winter & summer rims!
93 F250 4x4 95 Olds Silhouette 95 LHS 03 Corolla 10 Kizashi S MT
Return to “Kizashi Technical Support & Problem Troubleshooting”
Who is online
Users browsing this forum: No registered users and 1 guest
