114 days; Part II
I gave up on alignments, preferring to ruin the tires then replace.
lol...yeah, that's what I'm starting to think. If I don't have any driving or handling issues, which I haven't since this guy did the last one, and it's gonna eat tires anyway it appears so why bother right?
AND I pound the whee-snot outta mine, bounding at high velocity down most-any-surfaced "road". I laugh when I hit a particularly vicious deformity, thinking 'alignment on the fly'.....
The two new-to-me Contis I mounted on the rear yesterday are still holding air, and they worked pretty good on the wet / gravelly / muddy / sloshy / heaved paved roads I maniac-ed still I tested them on.
72,375
The Conti's I 'found' are run-flats; serendipitous, ay?
(Except they weigh 28lb each).
I tested a tank of 91 octane non-ethanol, and returned 27.1 MPG.
Not, IMO, worth it.
While the K-car was up getting its new shoes I took a look at the not-right rear shocks, and (stunningly) found them still fairly clean, and not leaking!
72,466
Last tank mixed 29.4 MPG.
73,289
Last tank maniacal 26.5 MPG.
I think I need to lower the rear tire pressure a bit; 'greasy' rear traction while cornering.....
73,589
So that's what I did; I set the fronts to 45 and the rears got 42 PSI. Seems to have better grip on unpaved surfaces, but I await more experience on paved.
Push, but push slow......
73,822
Funny. I've had my 2011 SLS for over 3 years and had 33K on clock when I bought it. It has 79K plus now. I replaced the Dunlops at 45K (that's not a mis-print) and had it aligned. Never aligned again. So I got 45K out of the stock tires, and there's 35K on my Conti's with a boat load of tread left and the wear totally even. I rotate them when I change the oil which is about every 5K. While don't drive like WESHOOT2, I don't drive like my grandmother either.
2011 Kizashi SLS CVT (silver)
2005 Honda Odyssey
I was thinking about how I drive as I drove back from lunch right now.
I drive often in a criminal anti-social manner.
I'm not a road-rage type, but I may get physically close to other traffic, not as intimidation, but simply to use the space.
Sometimes I go wildly inappropriately fast (I mean reallyreally fast), but I try to save those moments for less-traveled roads so prevalent in this region.
I look for, and like getting air.
I pick my battles.
Sometimes I just cruise.......but then the wild hair strikes and I'm compelled to push the accelerator pedal to the floor, and hold it there.......
The leaves, and views, are currently stunning.
73,930
How do you keep the flashing lights at bay?
2005 Honda Odyssey
