Hi all,
Love the look of the kizashi so i went to test drive a AWD sport model today. Love the handling of the car so much! Wish to join this club ASAP.
The demo I drive is brand new one, however, it has noticiable vibration on the steering when stopping at traffic lights and stop the car completely. (Last for half a sec)
Is it normal the cvt version?
Thanks
Alan
Steering virbration during a test drive
Is it a type of rough engine vibration, noticeable mostly when you stop abruptly? If so, it's most likely what others have noticed (including myself), when braking hard the CVT is lazy to adjust the ratio and that brings the rpm in "dangerously" low territory, causing kind of an engine shudder. The engine doesn't stop, but you feel the vibration for a second or so, until the rpms get back to idling values.opps2888 wrote:Hi all,
Thanks
Alan
A bit annoying, but benign, most likely. Try it in manual mode and apply some engine braking before braking hard, to see if this is the issue (the rpms will not drop so low if you're already in first "gear" and you should not feel that strong a vibration).
Are you referring to the vibration in the steering wheel while you're braking? If so, then that's perfectly normal. I picked up my Kizashi with almost 0km on the clock and for the first 2,000km I had vibrations in the steering while I was braking; this is due to the brake disks and pads bedding in hence its perfectly normal and goes away after 2,000-5,000km of driving.opps2888 wrote:Hi all,
Thanks
Alan
Also there might be a bit of vibration in the steering while driving due to the tyres being out of round since the car was sitting in one spot for a long time in the warehouse waiting to be sold; this is also normal and will go away after around 5,000km of driving.
Good luck
BMW E46 330i SMG
Suzuki Kizashi 6MT
Suzuki Kizashi 6MT
