2011 Kizashi...90K kms
The car started to stall and the "Hill Hold Disable" came on. It went away and a few days later the check engine light came on and found out the TCM needed to be replaced. New TCM and the same thing happened. The car starts to shut off while driving and then comes back on. Car shook a bit and lights flickered and then "Check Engine" light came back on. Brought it back and the new TCM was blown. It seems to be perhaps a wiring issue? I know last year there is one fuse under the dash board driver's side that when blown would not let you put the car in gear and no signal light would work and the "Hill Hold Disable" would come on. Anyone have any idea on what is causing this. This is such a great car I just want to know what is the cause of this. The dealers are not even sure. Thanks.
