Kizashi maintenance parts and fluid list
FmrLCpl
This is the info I collect for my 2012 Suzuki Kizashi SE AWD
Please keep in mind, I have my car for only 6 months and around 5K miles, thus I only did oil change so far. If you guys have anything to add, or to correct, I'll update this post regularly.
CVT fluid: Suzuki CVT GREEN 1, Shell GREEN 1V LUBEGARD® Universal CVT Fluid, Valvoline SynPower CVT (syn), Valvoline CVT (syn)
Transaxle oil Manual transaxle: 2.5 L (5.3 US pt) - GL-4, 75W80, 75W85, 75W90
Rear differential oil: 0.8 L (1.7 US pt) - GL-5 (Hypoid gear oil), 80W90, 75W85, Valvoline SynPower Gear Oil (syn)
Transfer gear box oil: 0.9 L (1.9 US pt) - same as rear diff oil???
Engine oil: 5W30
Oil filter: Bosch D3325, Fram: PH4386, Purolator: PL14477 (this is what I use)
Air filter: Fram CA10998, Purolator A36123, WIX 49008, K&N 33-2441
Cabin filter: Fram CF10546, Wix 24120 (<-edited)
windshield wiper: 20", 24"
brake pad front - Akebono W0133-1847728
brake pad rear - EBC Brakes DP21193
2012 Kizashi SE AWD (purchased Dec 2012)
Blue Ext, Beige Int.
My maintenance guide for the 2010 only lists these two CVT fluid types: Suzuki CVT GREEN 1, Shell GREEN 1V
No mention of any Valvoline products. Does the 2012 guide list them?
Rear diff and AWD transfer gear case are the same weight and type of oil.
Good list with everything in one place 8-)
11zukizashi
Here are 15 part numbers from some nice sets of HAWK performance brake pads that come up as compatible on their search system
Part # Description
HB145M.570 Disc Brake Pad; Black w/0.570 Thickness;
HB145E.570 Disc Brake Pad; Blue 9012 w/0.570 Thickness;
HB145W.570 Disc Brake Pad; DTC-30 w/0.570 Thickness;
HB660W.661 Disc Brake Pad; DTC-30 w/0.661 Thickness;
HB145G.570 Disc Brake Pad; DTC-60 w/0.570 Thickness;
HB660G.661 Disc Brake Pad; DTC-60 w/0.661 Thickness;
HB145U.570 Disc Brake Pad; DTC-70 w/0.570 Thickness;
HB145N.570 Disc Brake Pad; HP Plus w/0.570 Thickness;
HB660N.661 Disc Brake Pad; HP Plus w/0.661 Thickness;
HB145F.570 Disc Brake Pad; HPS Performance Street w/0.570 Thickness;
HB660F.661 Disc Brake Pad; HPS Performance Street w/0.661 Thickness;
HB145S.570 Disc Brake Pad; HT-10 w/0.570 Thickness;
HB145Y.570 Disc Brake Pad; LTS w/0.570 Thickness;
HB145Z.570 Disc Brake Pad; Performance Ceramic w/0.570 Thickness;
HB660Z.661 Disc Brake Pad; Performance Ceramic w/0.661 Thickness;
im going to try the HPS 'space' pads:
Code: Select all
This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology.
FmrLCpl
Ronzuki wrote:My maintenance guide for the 2010 only lists these two CVT fluid types: Suzuki CVT GREEN 1, Shell GREEN 1V
http://www.valvoline.com/pdf/cvt_fluid.pdf
Valvoline CVT fluid recommended for use where the following fluids are called for:
- BMW Mini Cooper EZL 799
- Dodge/Jeep NS-2, CVTF +4
- Ford CVT23, CVT30, Mercon C
- GM/ Saturn DEX-CVT
- Honda HMMF
- Hyundai/ Kia CVT applications
- Mercedes Benz 236.20
- Mitsubushi CVTF-J1
- Nissan NS-2
- Subaru Lineartronic CVTF
- Suzuki TC, NS-2, CVT Green 1
- Volkswagen/Audi TL 52180; G 052 180
We could get in to an extremely long discussion regarding the differences between what's "recommended for use" (by an oil company trying to sell product) and what "meets or exceeds" the specifications of what Suzuki recommends. All I'll say is for warranty purposes, we really need to be careful since Suzuki really has no reason to honor anything any longer if we haven't followed their recommendations to the letter. If it isn't on Suzuki's list somewhere, in writing, it isn't going in to my car. Especially something as expensive as the CVT. I just bought a bottle of the Suzuki stuff ($14) at the dealer while I was there getting my steering wheel swapped. I also use Suzuki oil and air filters in both our cars as well and don't pay anymore for them there as I would for high quality WIX filters at NAPA.
11zukizashi
What steering wheel did you get? Did you successfully add paddle shifters? I have been wondering if that could be done
11zukizashi wrote:What steering wheel did you get? Did you successfully add paddle shifters? I have been wondering if that could be done
The leather was starting to check/crack in a couple places. Swapped w/ OE under warranty. The parts guy said the wheel was $900, and that doesn't include the airbag assembly!
11zukizashi
Oh yeah that happened to me too the warranty repair order was like 890 bucks
pidru
I think OP listed an incorrect part number for the WIX Cabin air filter. Oreilly Auto Parts shows as #24120. The picture looks the same as the original cabin filter. Price wise it is 2x the cost of the FRAM model.
I just installed the FRAM CF10546. However it has less folds as the original unit. Somehow, I can tell the fan speed is not as strong as before. Am I just imagining this? :cry:
pidru wrote:I think OP listed an incorrect part number for the WIX Cabin air filter. Oreilly Auto Parts shows as #24120. The picture looks the same as the original cabin filter. Price wise it is 2x the cost of the FRAM model.
I'm sure you're right as the same WIX part number is listed for both the engine and cabin air filter in the original post. A quick search gave these two results for WIX cabin air filters to suit a Kizashi:
http://www.ebay.com/itm/WIX-24120-Cabin ... 0385148733
So, 24120 seems the correct option - I'll edit the post.
pidru wrote: I just installed the FRAM CF10546. However it has less folds as the original unit. Somehow, I can tell the fan speed is not as strong as before. Am I just imagining this? :cry:
All things being equal, less pleats = less surface area = more resistance to airflow. :|
