Strut Bars and Rear Sway Bars
KansasKid
bootymac wrote:I only know of White Line and RRM/Progress rear sway bars, but White Line dropped the Kizashi a long time ago and RRM cleared their stock out with the $200 sale.
Often, I'm upset with my self for not indulging in impulse purchases more often. This is one of those times... :facepalm:
Yeah, I kinda feel you, but I also know how distribution works and there's a set in a warehouse sitting there collecting dust that the distributor would be happy to get rid of.
SamirD wrote:Yeah, I kinda feel you, but I also know how distribution works and there's a set in a warehouse sitting there collecting dust that the distributor would be happy to get rid of.
Sounds like RRM is all out of them, but did anyone check with Progress; the actual company that manufactured them?
If any of you are feeling creative, you might be able to make your own chassis braces with square tubing or similar. I reinforced my GTI's subframe with steel square tubing and it made a huge difference on that soft chassis. All you need is a decent saw and drill bits :)
bootymac wrote:If any of you are feeling creative, you might be able to make your own chassis braces with square tubing or similar. I reinforced my GTI's subframe with steel square tubing and it made a huge difference on that soft chassis. All you need is a decent saw and drill bits :)
I would have bought the RRM brace if it wasn't so expensive. However, I imagine someone who welds can easily make something like that.
For your GTI, how did you mount it? I'm reluctant to drill into the frame given it's coated and/or galvanized for rust protection. I think drilling into the metal may compromise that.
I don't know how to weld so I had to mount the braces using bolts. Some holes were prethreaded but I had to drill others. I only worked on the subframe though as I didn't want to muck around with the car's frame.
Here's an aftermarket example of something that could be easily done yourself:
My DIY braces made of 1" x 1/16" steel tubing:
