Ok and were does the connection for the ground is in the car? The ground connection near the amp?SAEED_KIZZY wrote: ↑Thu Sep 28, 2023 4:43 pm @Klaa$vaaK, those are audio in of AMP and covered with shield signal connected to body ground all of this info is shown in the wiring diagram. you need to read the service manual for more information and signal description.
If I run new wires should I use the same insulated wires? What did you use for your setup Saeed?
KlaasvaaK
