Stock stereo subwoofer adition help.
Some info I just discovered today - for the 7 speaker non RF headunit (which as a side note is made by Panasonic) there are five "twisted pair" wires for speakers on the factory loom. It threw me at first, but then I checked in the boot below the parcel shelf and the wire colours match (green/yellow and grey)- so it appears they are prewired for a boot subwoofer. There would also be enough space under the dash to mount a small mono amp...... So, who is going to be the first to give it a try? (It's just a pity they also saw fit to spot weld a metal plate over the sub hole in the parcel shelf?!)
Where would be the best place to wire a subwoofer from the trunk into the radio system? I heard it was pretty tricky and was looking for tips from anyone who has done it before. Thanks!
What I posted above would be the easiest option. Get a small mono amplifier that has speaker level inputs, wire that up and hide it under (or in) the dash. Use the green/yellow and grey wires that run down to the boot parcel shelf to drive the sub.murcod wrote:Some info I just discovered today - for the 7 speaker non RF headunit (which as a side note is made by Panasonic) there are five "twisted pair" wires for speakers on the factory loom. It threw me at first, but then I checked in the boot below the parcel shelf and the wire colours match (green/yellow and grey)- so it appears they are prewired for a boot subwoofer. There would also be enough space under the dash to mount a small mono amp...... So, who is going to be the first to give it a try? (It's just a pity they also saw fit to spot weld a metal plate over the sub hole in the parcel shelf?!)
Here in India the Kizashi comes in only one trim. While it gets most of the good stuff, it lacks the RF stereo anyway, I decided to overhaul the sound keeping the stock HU. Getting some mid to high end Focal or Rainbow components up front, Rainbows in the rear doors, still searching for a decent 2" speaker for the dash; suggestions would be appreciated The speakers will be managed by an Infinity Kappa 5 amp
Now for the sub: I have a very showy thumping system in my Mitsubishi but at the end of the day I like clean, more detailed and wide sound and in any case the speaker upgrade should give me some better bass. Still, for that little bit extra, I do need a sub. Not gonna go for the fancy dual vented 12" subs or anything like that, Nor do I want those under the seat things since they are simply annoying. I want to get something that fits in the factory setup. 8" sub right? Now I see the wiring, but as some other members have said, they have welded over the hole. Is it recommended to get it cut out? How do I go about fitting a sub where it is meant to be in the Kiz? I need all the info I can get since I seem to be the first guy willing to do this and I REALLY don't want to mess it up. Already got a JBL monoblock to drive the sub.
I'm interested to see how it turns out. The amplifier should address what I think is the biggest downfall with the head unit- no power.
I think I' ve seen special drill bits for doing spot welded joins on vehicles, but I can't think of any way to remove that welded cover without making a mess of the surrounding metal.
The info is out there.... even some of the required parts (if you're in Australia and keen...)
eg http://www.rockfordfosgate.com/oem/Vehi ... x?id=12349
http://www.edmunds.com/suzuki/kizashi/2 ... .html.html
http://www.gumtree.com.au/s-ad/marion/a ... 1019439315
