Not necessarily - watts is watts. You can get a 1000W sub amp or a 5x200W amp, same price (or close, anyways).
As a matter of fact, this is a pretty accurate way to determine the "real" rating of the amp, not the "ILS" (if lightning strikes) wattage printed on the label.
Difference between RF audio systems?
Got this information from RF if it hasn't been provided already.
- 120402 Audio Setup 990B0-35022 Kenwood-Rockford .pdf
- (1.62 MiB) Downloaded 427 times
Just had a quick look, as an example, sticking with RF:~tc~ wrote:Not necessarily - watts is watts. You can get a 1000W sub amp or a 5x200W amp, same price (or close, anyways).
Mono: http://www.crutchfield.com/fg_347250_FF ... l?tp=35834
5Ch : http://www.crutchfield.com/fg_347150_FF ... l?tp=35808
Of course there are plenty of other brands, but cheap "no name" brands are probably not a wise choice. (Particularly for a dual voice coil sub amp.)
That looks like a good find.CCrunner84 wrote:Got this information from RF if it hasn't been provided already.
I'm surprised in step 8 it doesn't say to set Subwoofer to "OFF".
Step 15 appears to be pumping the equaliser gain right up at the 50Hz (ie. sub type frequencies) range. That's interesting.
The Kenwood Navi does have an option for crossover for the front, rear, and sub. I believe stock they are all set for straight through and the amp is handling the crossover.murcod wrote:You may also find an option within the Kenwood menus for switching the subwoofer output on/off on the RCA output. With it off, the full range should get fed to the normal front/ rear RCA's.
Thank you! They sent me this one when I contacted them.CCrunner84 wrote:Got this information from RF if it hasn't been provided already.
Did they tell you anything about the crossover settings?
- Kenwood.PDF
- (615.43 KiB) Downloaded 400 times
I'm still trying to get more information from him, this is what he said about the crossover...
"Just got word back from our OEM department. There is no separate subwoofer control. With the Kenwood head unit you need to make sure that the speaker outputs are full range. All crossovers, level and DSP are done in the remote amplifier."
Makes it sound like changing anything in the Kenwood units is futile.CCrunner84 wrote:"Just got word back from our OEM department. There is no separate subwoofer control. With the Kenwood head unit you need to make sure that the speaker outputs are full range. All crossovers, level and DSP are done in the remote amplifier."
Somewhat, basically you don't want it doing any crossover in the head unit.
Yeah, that was the problem with ours--someone had messed with them and basically killed all the fidelity of the system. Once I set everything to straight through, I was pretty happy.CCrunner84 wrote:Somewhat, basically you don't want it doing any crossover in the head unit.
