I'm not sure where the water is coming from. My two months old Kizashi always have water dripping . I have checked all the levels of coolant, wiper cleaner and everywhere where uses water and they are fine, sign of any leak. However the dripping start after 1 minutes of starting my car.
Possibly due to the AC, but I noticed the dripping happens pretty quick compared with another cars. I always leave a trace of water drops everywhere I go.
Is this normal? I know the AC on the Kizashi is very good cooling and it feels cold right away. Is this cause by the AC?
Water dripping
Yes, I could bet money it is because of the A/C.hocaspocas wrote:I'm not sure where the water is coming from. My two months old Kizashi always have water dripping . I have checked all the levels of coolant, wiper cleaner and everywhere where uses water and they are fine, sign of any leak. However the dripping start after 1 minutes of starting my car.
To convince yourself, turn A/C off and see if you leave water
2010 Suzuki Kizashi S MT
I concur... AC condenser runs very cold in all cars... so when it's in the hot engine bay, it develops water condensation... and drips.AlexRuiz wrote:Yes, I could bet money it is because of the A/C.hocaspocas wrote:I'm not sure where the water is coming from. My two months old Kizashi always have water dripping . I have checked all the levels of coolant, wiper cleaner and everywhere where uses water and they are fine, sign of any leak. However the dripping start after 1 minutes of starting my car.
Every car I have ever seen does that if you run the AC.
2011 Suzuki Kizashi GTS - Red - CVT
Rockford System with Kenwood Navi
Rear 'Suzuki' and 'Kizashi' Badges Removed
Do you mean water is dripping out your tail pipe, only when the engine is cold?lookin wrote:what about the exhaust
On newer cars... that's a similar cause... cold exhaust pipes, that get hot when the engine is warming up... however, on OLD (100k miles or over usually) cars... that COULD indicate a blown head gasket, however, that usually looks like white smoke, than water dripping.
