Well, three reasons.peezi wrote:Why would you want to buy used sensors and then have to deal with installing them yourself? Just go to Discount Tire and they will do the whole thing in 45 minutes. Its worth the extra $90 dollars and if something goes wrong they will resolve the problem for you. Plus, I think those things have batteries, so used = shorter life span...
One, from my experience of owning an aftermarket parts distribution company, genuine parts are always better than aftermarket, even with OEM setups like VDO and Suzuki have. Suzuki may have specified extra long-life batteries that VDO doesn't put in their sensors. Hnece the extra cost. No way to know this for sure, but it's rare to see a genuine part at 4x the cost of the aftermarket one without something significant being changed.
Two, used genuine sensors have a good shot of being in really good shape, especially since the oldest they could be is from 2010. Most probably come off a totalled car (like two unforunate owners that recently had their Kizashi totalled), which had perfectly working sensors with no problems. These cars get sold to salvage yards by the insurance companies where they are dismantled into parts that can be sold. A full set of 4 genuine Suzuki sensors can be had for as little as $65 in my experience. That's just 1.5x the price of a single aftermarket sensor.
Three is one of personal experience, but in almost anything that can be done to my cars, I find my own workmanship is superior to almost any technician that I'm paying somewhere else. Whether it's paying attention to torque specs (which are quite important on our tpms sensors and lug nuts), taking an extra second or two to make sure oil doesn't drip, being careful with the paint finish when leading on the hood, or a hundred other things that separate good work from excellent work, I've not found someone that I can rely on that will work with the level of precision that I do. And precision is important for most Japanese cars as their procedures and specs are quite detailed. To each their own in this area as our goals are all different for our cars. My goal is to drive it forever, so I want everything done right.
You are correct that you can't install the sensors yourself, but if you're going to have a second set of tires, you're just going to be mounting tires anyways, so the cost there is the same. $65 vs $190 is a big difference for most of us. Even if you take off $80 for mounting 4 tires, it's still $110 for the sensors. And you have no idea if what they use are the good VDO ones or the crappy Dill ones with the rubber valve stem.
I'm glad the $190 worked for you and got you back on the road. Personally, I might have taken a different route with what I know about tpms on our cars, but to each their own.
