Malfunction light on, car won't go over 5 mph
Sounds like it went into Limp Mode which is a mode that some cars will go into when there is a critical sensor or electronic component failure. It's basically so you can get the car to a safe place, but it will prevent you from driving the car to minimize damage.
My guess is that a sensor went bad. If not that, some other critical electrical component.
This should be covered under the powertrain warranty.
Please keep us posted on it. Thanks.
I always thought limp mode locked it on 3rd gear or something. I would think it would do better than 5mph. That alone can be extrememly dangerous depending on where it happened!
Yes, my thought is ouch.toebridge wrote:Got it towed home today from Buffalo NY to VA and ready to tow it to the dealer 85 miles away. Any thoughts?
Yup, agree that it's either a sensor or something major went wrong with the tranny. What kind of revs were you getting while going only 5 mph? Since there's no "gear" to lock into in a CVT, I'm not sure how the limp mode works. I imagine the pulleys simply both lock in a particular position. I think if the hydraulics failed that squeezes the pulley on the power side (engine) it would have the belt riding very low on the pulley giving a very high ratio and hence not much speed. That's just a guess though. I would think that even in that situation you'd be able to get more than 5 mph out of it.
Tim
Tim
So you plan to get the transmission replaced under warranty and then sell the car once that's done?toebridge wrote:Got it to the dealer - Transmission is shot - under warranty- time to get rid of it -
