2011: https://suzukiautomotiveparts.com/2011- ... 7L00-item/
Yeah there's always sketchy ways to get the things out, but as I said, I'll just replace them entirely.
Control arm ball joint
Ronzuki wrote: ↑Sat Oct 27, 2018 2:26 pmNope. The LCA is an assembly, as is the case with most modern vehicles.OliverB wrote:Does anybody know if the ball joint on the lower control arm can be removed? I might have to replace mine and spending 700$ for both isn't quite... ideal. I could always find control arms from wrecked Kazashis, but I figured I might aswell ask on here first.
Cheers!
LH p/n 45202-57L00
RH p/n 45201-57L00
There is a also seal kit associated w/ that ball joint as well: 45714-57810
Same p/n for both sides...one kit req'd per side.
p/n's from US spec 2010-2012 parts catalog.
So this seal kit does it fix the noise the ball joints make?? Before I go spend 500$ on a pair of new control arms
