Page 1 of 1
bumper attachment to underbody plastic panel
Posted: Sun Apr 07, 2019 6:13 am
by chazyouwin
Has anyone dropped the bumper to replace headlights, then wondered how the underbody protective panel gets put back together competently with the bumper? I think the little pointed screws kept the underbody panel attached to the bumper, but now they seem shaky in that capacity. Maybe an extra clip-nut or a few?
Re: bumper attachment to underbody plastic panel
Posted: Sun Apr 07, 2019 7:20 am
by BLyons
There are 6 screws total, and they should each have a clip. I lose a couple every year, but they always seem tight when I put them in, so I'm not sure what you mean when you say they're shaky.
Posted: Sun Apr 07, 2019 2:48 pm
by chazyouwin
When I took out these screws for my bought-new Kizashi, the only screws with a nut-clip were the ones holding the two little visor protective attachments at the front bottom of the bumper. The bumper and bottom plate plastic pieces were just screwed together with the same pointed wide round head Phillips screws. Yet they were strong enough, and I recall no work being done at any prior time (yes, my original low beam light bulbs lasted for 78,000 miles then went out at about the same time). But now that I am putting these items back together these connections seem shaky as the plate and the bumper down there are both flexible. I'll check on the clips, probably can use standards.
Posted: Sun Apr 07, 2019 4:41 pm
by chazyouwin
"they should each have a clip" - okay, that's the key. Found one of the clips got moved away on the panel and the other on the driveway. Mystery now confined to three screws, none of which is strictly necessary. Thanks!
