Page 1 of 1
Serpentine belt replacement
Posted: Sat Feb 01, 2020 5:11 pm
by dslatsh
I know a few of ya guys have done this but I was curious as to has anyone noticed of there's any certain belt should use/works better? The oem belts are like $50.....while can get other brands for around $20....
Re: Serpentine belt replacement
Posted: Sat Feb 01, 2020 7:27 pm
by old tech
Get a Bando brand belt on eBay 6pk1795 . Right now running about $24 . While ordering get a belt tensioner if you have over 100,000 mi. Febest 0790-grv $34
Posted: Sun Feb 02, 2020 4:04 am
by KuroNekko
old tech wrote:Get a Bando brand belt on eBay 6pk1795 . Right now running about $24 . While ordering get a belt tensioner if you have over 100,000 mi. Febest 0790-grv $34
Do you recommend replacing the whole tensioner or just the pulley? Aftermarket brand like Febest recommended?
I have Bando belt on standby I got on Rockauto.com. I don't think I paid more than $25 for it. Bando is a Japanese OEM. Part made in Japan.
Posted: Sun Feb 02, 2020 5:52 am
by old tech
I recommend the complete tensioner . The pivot portion gets tweaked by the leverage of the tensioner arm . This is easy to check the condition of the unit by simply rotating crank bolt counterclockwise while watching from the underside the belt at tensioner pulley. A new tensioner will keep the belt squarely on pulley while with a worn one you will see the belt work its way off as you turn it. The ones really in danger will jump a rib groove on the crank pulley within 6 revolutions . The oem one is great to use but is a lot more expensive then the Febest. Both have the word China on them. Harbor Freight sells a metric offset box wrench set for $15 that works great for breaking loose that top bolt if it is still a factory 12mm head. Some have a 6mm allen as a top bolt. Both will come out without moving the water pump .
Posted: Sun Feb 02, 2020 7:18 pm
by BLyons
Home Depot has the Bando belt for less than $20. Free shipping for store pickup.
Posted: Sun Feb 02, 2020 7:50 pm
by old tech
When changing the tensioner use oem or Febest. The other copies arent worth the risk. Earlier I posted a price for Febest at $34. i was fooled . that was a cheap copy using the name Febest in their listing . The real Febest has a large specially shaped cover on the front of the pulley just like the oem where the knockoff just uses a washer. Currently the best price is $49.95. The offset box wrench set i referred to is Pittsburgh 8pc item no 32042
Posted: Tue Feb 04, 2020 6:43 pm
by dslatsh
well crap I pulled the trigger and got the dayco belt off amazon...was 1 left so i didn't want to wait. This one,
but mine is around 80k...should i still plan on replacing the belt tensioner? My car did have that voluntary pulley etc. replacement done...
Posted: Tue Feb 04, 2020 6:49 pm
by dslatsh
Looking for that febest it doesn't say its compatible with the kizashi....
Posted: Tue Feb 04, 2020 6:54 pm
by old tech
It fits if it has that part no. i listed. be careful though for the cheaper knockoffs
