Okay I have three questions, so I will get straight to it.
For those that do not know I have a 2015 base grade Suzuki kizashi FWD.
So my first question is about the CVT cooler filter. I look around every where in my engine but I could not find a filter so I asked the dealership and they said no there is not cvt filter and they showed me a diagram of it and there was no mention of a filter in it. There is also no mention of it in the diagram of megazip too.... Any ideas?
Second question:
What should the engine compression or the compression in piston chambers be, asking because I am when I check it I should know if my engine is tip-top condition or not.
Third question:
Does anyone know the part number of the fuel filter because I could not find it in megazip, all they have listed is a fuel pump. Or does the pump and filter come as one unit?
Thank you for your time
Stay safe
Question time
There are two filters for the CVT, a wire screen inside the pan and a cartridge type filter where the cooling hose goes into the cooler. http://www.kizashiclub.com/forum/viewto ... 621#p39621
The fuel filter is inside the gas tank and a major job to replace. Scheduled for 150K miles, I'd ignore it unless I had a specific reason to suspect it.
Compression test should be done with engine warm, all plugs removed, and throttle held wide open. Factory standard is 200 psi and 160 is the lower limit.
