Suzuki Kizashi output speed sensor spacer/Shims
00SecretAgent
Suzuki Kizashi output speed sensor spacer/Shims..?
Does anyone have any knowledge on how many shims "1 or 2" and placement..?
Thank You..!
00SecretAgent wrote: Tue Jul 12, 2022 12:09 pm Suzuki Kizashi output speed sensor spacer/Shims..?
Thank You..!
Yes, both the Kizashi and the Sx4 come from the factory with 2 washer/shims between trans case and sensor . Only on the output sensor though. The code is reporting an improper count which near always is belt slip or missing. Belt slip and breakage usually is primary pulley breakage or jamming from broken and peeling ball bearings
