Memory Seat
kmr296
have a brand new 2011 GTS Kizashi. Can't get the seat to remember my setting. I hold M then the number. It beeps. move the seat, press 1, and it doesn't move. My buddy has the SAME car, tried the same procedure in his, works perfect. Any ideas?
xwiredtva
Put the car in park, pull the ebrake.
metatrox
Yeah I know for sure it has to be in park not sure about ebrake.
I've caught myself a couple times I'll hop in the car after my wife(short) and press my number but then put it in reverse before the seat fully moves causing it to stop partial way.
2010 SLS, Platinum Silver.
kmr296
Thanks guys... I will def try this in the morning and post that it worked
RjKizashi
I didn't pull the e-brake to set memory
Rj Arizona
2010 Kizashi SLS AWD/Wifes
jimmerz
You do mean you are pressing and holding the M AND the number at the same time right?
Good luck.
2010 Suzuki Kizashi SE
CVT AWD
Black
kmr296
Confirmed - has to be in park before you can select a position from memory. Thanks for the help
