Kizashi Differences Around the World
~tc~ wrote:Checked, and the switch is the same shape in our door panels - where the switch goes is just blanked out. Curious if the wiring is there (it could very well be). If only the switch and mirror housing needed to be changed, that would make an awesome swap!
Even if the wiring harness would have to be changed, it wouldn't be that hard as you'd have access to it when swapping the mirrors. 8-)
Anyone willing to get us part numbers? I guess either one of us will need to open up our door panel to see if the wiring is there. :?
paininthenuts wrote:This is it
Thank you! That's exactly where I thought it would be, although the switch is different than how I expected it to be. I'm assuming it works like the window lock button, staying pushed down when pressed, correct?
