rear brakes fail before front?
PittsburghJoe
Hi All,
I'm curious as to why my rear brakes failed before the fronts. I'm just a shade tree mechanic but it seems atypical to me. I have just shy of 40k on my 2012 SLS and I heard a metal to metal rubbing noise on the rear driver side and upon inspection sure enough the brakes and rotors on that side are toast. The passenger side is not as bad but getting thin. Front brakes are starting to thin but I would estimate I can get another 10k on them. Any thoughts?
Thanks,
Joe
Not an expert on this field but I believe brake bias and also the brake pad and rotor size from front vs. rear are factors.
The front brakes typically do most of the work, but if the car has stronger rear brake bias than other cars, the rears work more and wear out faster.
It can also be because the front pads are larger and thicker. This would more evenly spread the braking surface so they last longer.
Lastly, from what I see sold online, the front and rear brake pads are actually different products and not the same pad. They are apparently different grades of brake pads. The fronts are probably made of better materials that last longer.
As I stated, I'm no expert and I haven't had to service the brakes on my Kizashi yet but these are my guesses.
Kuro nailed it. Brake bias and different pad compound pretty much covers it. It happens on other vehicles too
I HAD TO replace my rears at 83K; I DECIDED to replace my fronts at 90something.
And I just checked the pads today; fronts nearly gone, rears look like they'll last forever.
I'm running StopTech slotted rotors and their mating metallic pads.
paininthenuts
WESHOOT2 wrote:I HAD TO replace my rears at 83K; I DECIDED to replace my fronts at 90something.
I wonder what their children will look like ?
Do you use the e-brake a lot?
PittsburghJoe
~tc~ wrote:Do you use the e-brake a lot?
almost never but how would that effect the pads/rotors? I'm certainly not an expert. Just curious.
On most cars, the e-brake adjusts the pad clearance on the rear brakes. Using it a lot can result in them being adjusted a bit too tight and premature wear on the rear brakes.
PittsburghJoe
~tc~ wrote:On most cars, the e-brake adjusts the pad clearance on the rear brakes. Using it a lot can result in them being adjusted a bit too tight and premature wear on the rear brakes.
I see that now that I have the brakes apart. Now the problem is that I can't get the piston pushed in far enough to get clearance for the new pads. Any ideas? I'm using a large C clamp and it will only go so far!
PittsburghJoe
Ok, so if anyone is out there, I see on page 324 of the service manual what my problem is. It is indeed the ebrake situation. Step 1 says remove the console panel and has a little pointer finger indicating that I should be able to click it and learn how to properly do that but it doesn't seem clickable. Any ideas?
