According to the wiring diagram, DRL uses the same fuse and wire as the high beam.
When ignition is switched on, the in-line DRL module applies a lower voltage to the h7 Hi beam bulb.
When headlights switch on, the DRL module just connects the normal Hi-beam 12V circuit.
So it seems not possible to disable DRL's unless you unplug the H7 Hi beam.
Day Time Running Lights
An auto electrician can easily put a 12v relay circuit in line, so that only when the full 12v is applied (Hi beam on) it will connect to the circuit.
I should have thought of that first.
Very True...I test Drove the Kizashi & Loved it...so it didn't matter that it had the DRL's....Plus I wanted to be the only guy in my town with a Kizashipurpleanga wrote:A real Kizashi fan! You needed a car with no DRLs for your work but you still bought the Kizashi.NJKizashi wrote:How do I turn these Friggs Off ??
My Line of Work...(Insurance Fraud) I tail & Follow people in their cars all the time..I want to be a little less obvious and turn these guys off..is it a simple fuse..or is it a more complicated/electrical process ??
Thanks Guys !!
Get an Aussy Kizashi we don't have them, and I must say i'm glad we don't.NJKizashi wrote:How do I turn these Friggs Off ??
Thanks Guys !!
Are they those bright orange lights on your front bumpers or are they your turning indicators, looks to me like Suzuki at first forgot them, and later rushed down to the local Automart store in a panic and bought the first ones they saw. LOL
- TheHolyGhost
What i would give to get rid of those orange lights....
6 speed
Past Cars:
2008 Subaru Legacy 2.5i
1998 Audi A4 1.8TQM
1998 Dodge Avenger ES
6 speed
Past Cars:
1998 Audi A4 1.8TQM
I have a 2011 Kisashi GTS and there is clearly a second bulb for the running light - the H7 does not get a lower power to dim it. Look in the bezel - its clear as day.
Take out your headlights. Instructions here:
http://www.kizashiclub.com/forum/viewto ... f=28&t=272
Open the hight beam cap on the back and you will see the H7 bulb connector and under it there is a smaller connector for the DRL bulb. Take the plug off the back, pull the bulb, and then tape up the connector to keep dirt out - put the cap back on and reassemble.
does the 2010 have only 1 bulb in the High beam lens? I'd be surprised if they changed that from 2010 to 2011
Are you referring to the Orange bulb which is just a parking/running light?kmr296 wrote:I have a 2011 Kisashi GTS and there is clearly a second bulb for the running light - the H7 does not get a lower power to dim it. Look in the bezel - its clear as day.
Each headlight housing has 4 bulbs in it.
Ill describe them right to left of this image.
1 : Turn Signal bulb, which is furthest to the out side of the car.
2 : The Regular Headlights/LowBeams
3 : The Daytime Running(Low Voltage) and the High Beams (High Voltage) bulb.
4 : Just below the DTR and High Beam is an amber type bulb which is for Parking/Running lamp
- 8.jpg (64.37 KiB) Viewed 5971 times
2010 SLS, Platinum Silver.
