Kizashi Club
 #40013  by bootymac
 Tue Feb 02, 2016 8:55 pm
Thanks for looking out! Things get a bit sloppy on mobile.
And sorry, I should've mentioned that the catalogue was specific to Canada. A quick Google search yielded nothing for the US
 #40017  by SamirD
 Tue Feb 02, 2016 9:28 pm
Thank you so much for the info guys! I'm going to measure the battery in a bit and get all the specs off of it. Then I can just use bci sizes to figure out which one will work, which I'm sure will be more than one. This is how I found an AGM battery for the Porsche after 2 factory ones died.
I think the battery is probably fine. I think I had not seen it crank in the winter so I was a bit paranoid. I'm very sensitive to noticing changes on the car.
 #40019  by Ronzuki
 Tue Feb 02, 2016 9:47 pm
nytq wrote:I've got the 8020-164-35-optima-red-top in mine. I did add a bit of spacer on the crossbar holder as without it the nuts would bottom out on the available thread. You can also put a spacer under the batter. Maybe 1/4 inch. Besides that it works just fine.
http://www.amazon.com/Optima-Batteries- ... B000MS9VZK
I used an Optima Red Top as well. There was a rigid plastic cover frame of sorts on the top guarding the terminals. This device also doubled as a spacer beneath the battery to raise it up.
 #40042  by SamirD
 Wed Feb 03, 2016 7:05 pm
Delkor Battery
6.5-7" H (I didn't take the battery out of the tray to measure it
6.75" W
10 1/8th" L
Good to know about the red top. I wonder if they have a yellow top like that. I've had good experiences with the yellows.
 #40051  by SamirD
 Wed Feb 03, 2016 10:57 pm
I forgot to note terminal placment--positive is towards the front of the car, terminals are towards the passenger side of the battery, and post style on top.
 #40055  by bootymac
 Thu Feb 04, 2016 2:36 am
Are there any indications of reserve capacity on the stock battery?
 #40057  by SamirD
 Thu Feb 04, 2016 3:30 am
bootymac wrote:Are there any indications of reserve capacity on the stock battery?
Not on mine, but they seemed to use a few different manufacturers for the battery and some seems to have specs on them.
 #40063  by Woodie
 Thu Feb 04, 2016 11:46 am
bootymac wrote:Any BCI 24F battery should fit.
SamirD wrote:I forgot to note terminal placment--positive is towards the front of the car, terminals are towards the passenger side of the battery, and post style on top.
That's what the F means.
 #41875  by SamirD
 Sat Aug 06, 2016 1:51 pm
Good to know. 8-)
