Added dimming mirror with Homelink
golftango
Even though I had added an auto-dimming rear view mirror, I was longing for Homelink. Finally scored a new one on eBay for $50. No more separate garage door openers!
I now have an auto dim mirror if anyone's interested with harness. Two wires, one ground and one tapped to an ignition source. Let me know, I'll sell it cheap.
2019 Kia Optima EX Premium
Instagram: golftango
RedGeminiPA
The Kizzy isn't prewired for plug & play, or is that only select models?
2011 Sport GTS FWD CVT Nav
Altoona PA
golftango
RedGeminiPA wrote:The Kizzy isn't prewired for plug & play, or is that only select models?
Mine was not. I grounded right to the roof with existing hole and sheet metal screw. Ran the hot lead across headliner, down A pillar and tapped into a ignition wire right under the dash. 30 min job with a test light and 3M wire tap.
