Kizashi Club
The Kizashi should soon show up in Australia. We look forward to seeing members from your region.
 #18946  by murcod
 Mon Jul 01, 2013 3:02 am
Thought I'd post up a collection of info I've gathered on the above mentioned head unit. It was supplied by Suzuki Australia as the optional "Multi Media Kit" with GPS (from 2010-2011 for the first series of Kizashi.)
Technical info: http://my.kenwood.com/Car_Entertainment ... /DNX7360BT
Installation manual : http://manual.kenwood.com/files/4d097b75cf90c.pdf
Operation manual : http://www.manualslib.com/download/8614 ... 036bt.html
Head unit operating firmware upgrade to Version 1.6.0 : http://www.kenwood.com/cs/ce/mm/firmwar ... b/eng.html *** read the following post before considering "upgrading"
Garmin GPS software update (this is not updated maps) : https://buy.garmin.com/shop/store/downl ... &pID=62819
Info on updating GPS maps: Mapping software used is provided by Garmin. Updated maps can be purchased from various sources. The maps are stored on an SD card which is installed in the head unit. There are also other "ways" to find updated maps via Googling and trawling various forums........
 #32093  by murcod
 Mon Sep 22, 2014 1:43 pm
Just an update to the above info, DO NOT update your head unit firmware to V1.4.0 (or later versions- ie. V1.6.0) if you desire to retain continuous volume adjustment when the volume controls are held down.
For some stupid reason Kenwood have made the volume buttons increment the volume by one single step (no matter how long they're held down) in those later versions. To make it worse, if you hold the button down too long - or toggle it too quick - the head unit locks out the volume buttons for about 1 second before letting you try again!? :x
I'm now trying to find an earlier firmware version (V1.1.0 or V1.2.0) .... without much success. :(
