That's an interesting undocumented series of lights. Thank you for sharing them!
My guess is that the tpms system would have self-corrected itself, but only after several drives and days. I still remember some times when swapping tires that it took a few days for the car to even alert even with a different set of tires and sensors! And then there's also times when everything was relearned only for it to pop back up again after a week or more. (I think it happened to me 3 times one season and got me pretty concerned.)
The two flash with a pause sounds like the programmers did actually take into account this scenario and programmed the 2 flash pause as a way for them to know what has happened--probably 'multiple sensors of same id detected'--and this is probably the only place outside the actual coding documentation where anyone would find this as I don't recall anything in the service manual.
The sets of 3 also sounds like a specific programmed response. When you mention the rapid flash, it sounds different than the normal slow flash where the car is waiting for each tire to be triggered.
It just dawned on me--maybe the 2 or 3 flash is indicating which sensor ID in the system is duplicate?
redmed
Does the service manual describe some of the flash combinations?
17 Sienna
From what I recall it only mentions the tpms light blinking when it is in relearn mode, and that the light will blink indicating the remaining number of sensors to be relearned, but not the specific short-short sequence. It has been a few years since I've looked at it in depth, but I do recall that there was no mention of any specific light sequences outside of the relearn mode.
redmed
Apparently the clone did not take. I put the cloned wheels back on and I'm now getting one flash. The center screen acts normally and the ! symbol is not on, so I suspect the traction control and anti lock brake also work.
17 Sienna
Interesting. I'd try locking up the brakes to double-check, but I think you're right that the abs and traction control should still be working normally.
It is strange how the cloned sensors work but have that light. I wonder if a simple re-learn will clear it? Or maybe just driving a few more days?
redmed
At this point I'm going to just drive it, but knowing myself that blinking light will bug me until I do something about it.
17 Sienna
I'd feel the same way. Let's hope that driving it for a bit shakes it back into shape. The tpms system can be quite fickle that's for sure...
redmed
Well that flashing light finally got to me and I ordered a Autel TS508. Now the wait to find out if I made a mistake going with Autel stuff.
17 Sienna
I will be curious to see how it works out. I never found a single tpms tool besides the ateq vt30 that could trigger or even read the sensors. And I had also tried a Bartec one.
redmed
I passed on a VT55 without the OBDII cable for $100 thinking I would never need a TPMS tool. Now I'm regretting that. I read that ATEQ stuff is the best but Autel seems to be trying to become a big player with some innovative stuff. Like the MX-Sensors I bought that are supposed to work with all vehicles. When I contacted Autel support they asked what type of sensor was the OE sensor. A day later they replied that their stuff should be compatible, so being a Kizashi did cause them to do some research.
17 Sienna
