Problems with AM Radio channels on Navigation system
I bought 2010 SLS model with Navigation system. Since the day I bought the car, I am unable to tune the AM channels through Kenwood Tuner system. FM channels work fine. Dealer ended up replacing the Kenwood set and the issue is still the same. Dealer is thinking of checking wiring from antenna to receiver. Now woofer has started popping up which dealer agreed to replace it under warranty. Anyone with Navigation system, facing the same problem? If yes, please advice how did you resolve it? What exactly you did? Please share this with me - because without AM I do not enjoy my drive from/back home. Since, Nav model do not have USB, any ideas how to convert the iPod connector to USB. Thanks.
- Contact:
buy the cord for ipod-usb its available, and no am defently antenna issue
- Contact:
apple store caries and some area your local walmart
FEMALE on both ends? I've never even seen them. Why do you need a female iPod end? do you have a double male iPod cable??
2005 Pontiac GTO - 375 rwhp
I have a male ipod connector out of nav system, which goes into iphone. To vo nvert this to USB, i need a cable that has a female ipod connector at one end and female USB at the end, so that I can connect my standard male USB connector, which has a micro usb at the end for my BB. I found this cable at cablejive.mapeterson2 wrote:FEMALE on both ends? I've never even seen them. Why do you need a female iPod end? do you have a double male iPod cable??
http://www.cablejive.com/products/Unive ... erter.html
Any ideas about AM radio?
Thanks.
OOooo Ok, haha for some reason I couldn't quite figure out what you were trying to do.
