suggestions for new exhaust
sigma008
I would like to improve my exhaust with a little more growl without the annoying fart sound. Any suggestions?
nytq
Well the muffler I used is a single (centered) in and double out.
The original factory was single (centered) in and single (centered) out.
MAGNAFLOW PN 11148
Material: 100% Stainless Steel - Satin Finish
Body Shape: 3.5in.x7in. Oval
Inlet/Outlet Size: 2.25in./2in.
Body Length: 14in.
Overall Length: 20in.
Core Size: Dual 2in.
Position: Single/Dual
http://www.magnaflow.com/02product/shop ... in&id=9932
Bizzenn
What is the pipe diameter on the kizzy's?
Bizzenn
disregard, I must be blind I see it. Weird though that it is a different size in and out.
Bizzenn
Has anybody experimented with different mufflers vs. an entire exhaust system? Im curious because it looks like it has 3 mufflers from underneath.
sigma008 wrote:I would like to improve my exhaust with a little more growl without the annoying fart sound. Any suggestions?
Yeah. Be choosy who you allow to ride with you :lol:
2011 Kizashi SLS CVT (silver)
2005 Honda Odyssey
Bizzenn wrote:Has anybody experimented with different mufflers vs. an entire exhaust system? Im curious because it looks like it has 3 mufflers from underneath.
Yup, there are three mufflers as pictured in this post. A quick and easy way to change the sound of the exhaust is to replace the center muffler with a straight pipe, which any muffler shop can do. I have no idea what this sounds like on the Kizashi though, but it is reversible if you don't like the result
Here's a parts diagram if it helps. #5 would be the center muffler/resonator
Armykizyguy92
Yes I have experimented with it. At first I took of the back two mufflers and it sounded like a Sti. I undid the resonator and this is the sound I got that and a high flow cat give you this sound. I get nothing but compliments every where I go.
Custom exhaust, 20% tint
Galluzzo
Has any one just removed the resonator and kept the two stock mufflers?
Armykizyguy92
No but I just re did my exhaust (had straight pipes before) sand found out there are two resonators one small one in front of of the bigger on took it out and put a single in and single out flowmaster in with 2 1/5 in pipe from cat back loud and quite it's a good I between. Miss the straights though
