krell
Posts: 235 Joined: Mon Jul 15, 2013 9:14 am
Sat Nov 04, 2017 10:04 pm
My blower making a howling sound seem like the shaft bearing or bushing gone bad , how hard is it to change the blower motor.
Triggerhappy
Posts: 130 Joined: Sun Nov 14, 2010 4:39 pm
Sun Nov 05, 2017 1:22 pm
Pretty easy using a short screwdriver. I replaced mine in 2015. It's located on the passenger side under the glovebox.
2018 Pacifica Hybrid - wife's
mctator
Posts: 4 Joined: Wed Jun 22, 2016 2:46 am
Fri Jan 19, 2018 3:22 pm
Where did you get your replacement blower motor? I'm having a hell of a time finding one.
krell
Fri Jan 19, 2018 11:45 pm
Mine making a howling sound also... got a used motor from ALL FOREIGN PARTS in Pittsburgh PA 412782-5580 plenty on Flee Bay.
rossirob73
Posts: 55 Joined: Sun Jul 07, 2019 11:06 am
Sun Jun 07, 2020 5:19 pm
Triggerhappy wrote: Pretty easy using a short screwdriver. I replaced mine in 2015. It's located on the passenger side under the glovebox.
What part did you change as my car makes the same noise and it's annoying. Behind the glove box is the cabin filter..
Sent from my SM-J530Y using Tapatalk
soylentgreen
Posts: 7 Joined: Wed Nov 30, 2016 10:44 am
Tue Jul 21, 2020 1:28 pm
rossirob73 wrote: Triggerhappy wrote: Pretty easy using a short screwdriver. I replaced mine in 2015. It's located on the passenger side under the glovebox.
It would be the blower unit, it's responsible for pushing air into the cabin it sits behind the glove box, above the filter.
you can get second hand units off ebay or new cores elsewhere
https://www.fitinpart.sg/is a good start.
