Update on '11 sls 6mt fwd
Fresh wash and wax. Turbo system is going to have to wait some time ad this is my dd and just found out I have a kid on the way. But because of that I will be doing brake and suspension mods to help better the ride and safety
- image.jpg (249.41 KiB) Viewed 8709 times
- image.jpg (331.75 KiB) Viewed 8709 times
- image.jpg (410.83 KiB) Viewed 8709 times
- image.jpg (409.34 KiB) Viewed 8709 times
- image.jpg (398.33 KiB) Viewed 8709 times
Custom exhaust, 20% tint
Also don't mind the scratches in the rear one is from ice scraper and the others are from loading army gear in and out of the trunk
Congrats. Lucky you've got the perfect sized car for a baby/ child and don't need to buy something bigger!Armykizyguy92 wrote:... just found out I have a kid on the way. But because of that I will be doing brake and suspension mods to help better the ride and safety
PS: I don't know what tyres you're running, but if they're OEM that would be a good place to start for safety upgrades. I changed mine after having a "near miss" with my 5yo in the back, they just didn't have the grip to pull the Kizashi up. An upgraded rear swaybar is also an excellent upgrade for little outlay.
Yeah! In update New York the roads are really bad and practically have speed bumps on the highway which makes the rear squirmy. Front tires are Goodyear eagle ls2's rear are donlaps
No this is going in a straight line hit the bump and the rear wants to step out . Also found out my shocks are bad so that might be the problem
Yes, that would match up with your problem. I had the same thing on a 4WD many years ago - it wasn't much fun to drive on corrugated dirt roads.Armykizyguy92 wrote: Also found out my shocks are bad so that might be the problem
Mine is but then again it's fwd
The same sort of effect will happen as the rear end will lose traction over bumps.
PS: Possibly a terminology difference between countries - "4WD" is what you'd term an "SUV". It was an older type with manual transfer case to go from RWD to 4WD.
- Contact:
looks good bro, i deff need fogs!, im feeling how the front bumper looks on that model too
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
IG: N2OKizashi
