I believe it and I know that water pools in the recessed area where the coils sit. However, the coil boots are supposed to seal the spark plug hole. Regardless, it's why I have rags and soak up the pooling water completely. It's also advised that you run the engine shortly after and have the engine heat evaporate the excess water.murcod wrote:I mentioned leaving it on to help prevent water pooling in the spark plug area. It shouldn't happen, but sometimes it's better to be safe than sorry. I've noticed a lot of issues cropping up on a Grand Vitara forum I frequent from the "coil on plug" spark plug boots failing. Some people have posted pictures with rusty contacts inside the boots - so water has penetrated that area.KuroNekko wrote:I remove the cover when I wash my engine.
Engine Rattling
That looks great bootymac!
I've heard of a technique of spraying degreaser and using steam to 'wash' it off that does great. I've also heard of a method by which you actually spray on degreaser and water and drive around for 15 minutes (saw it on a prelude forum). I've never tried these methods, but I know steam can do a really nice job.
I rarely ever wash my engine. Probably once every couple years if that.bootymac wrote:Wet rag, but honestly I've rarely had to use a lot. The metals in my engine bays rarely get dirty enough to warrant it. I'm not entirely sure whyKuroNekko wrote:How do you rinse the degreaser?
