FYI (use - or ignore - the below at your own undertaking
1. A 12 point 1" socket is a neat fit on the "eye" drive point on the factory jack..... So, you can use either a ratchet handle
or a cordless drill/ driver and jack the vehicle up with substantially less time and effort. The supplied "handle" is just plain stupid and a PITA to use.
. Note: I wouldn't suggest using a cordless impact driver
2. You can raise the jack under the front jacking point higher than normal (but nowhere near maxxing the jack height) and lift
both front and rear tyres off the ground at once. The front wheel was around 10-15cm off the ground for the rear to be lifted enough to change the tyre.
(With point 2, I'd imagine the jacking height will vary with each Kizashi model. I don't have the "Sport" suspension, however my upgraded rear swaybar may have helped?)
