Range Display
KizashiBlack
Hi there,
We have had our 2011 Kizashi from new and not a problem until...
..Until we took it to get a wheel alignment. Since then the range display function remain at '---'. No Amount of resetting we have attempted has resolved this issue for us. It also did not become apparent until some weeks after the alignment, and was working intermittently for a brief period. All the other display options appear to be in working order.
Has anyone had this problem occur for them and what did you do about it? Or has anyone got any ideas?
Does your fuel gauge work properly?
Try disconnecting the battery. Remove the negative terminal with a 10mm wrench and leave it disconnected for at least 10 minutes. Reconnect and then see if the range display is still malfunctioning.
KizashiBlack
Fuel gauge works, speedo works, trip meter works.
We just put a new battery in it yesterday so we will give it a little bit to see if it comes back.
KizashiBlack
Thank you KuroNekko!!
A new battery and after a couple of days to and from work, the Range display has kicked back in.
Good to hear. A lot of times, minor electronic glitches like these usually get resolved by disconnecting the battery to reset things.
KuroNekko wrote:Good to hear. A lot of times, minor electronic glitches like these usually get resolved by disconnecting the battery to reset things.
IT Crowd knows what's up
redmed
You where probably out of range.
17 Sienna
