Hey guys
Update*****
It was the brake switch. Thanks for all your advice.
Appreciated.
Kizashi Wont Start Please Hellp!!!
- Contact:
Cool. Glad u got it fixed!
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
IG: N2OKizashi
Excellent to hear it's fixed. Thanks for the update. Good to know those things are still going bad in this day and age.
well guys,
apparently, the brake switch is not the problem. The car kept doing the same thing after awhile.
I took it somewhere else now, seeing that service the steering light came on.
I got the code b1162.
Mechanic said the problem is because the steering lock unit needs to change. So i ordered it and will see if that solves the problem.
Well now, that sucks. Hopefully your not at the beginning of a protracted game of parts darts.
If you are experiencing the no crank situation and a message appears on the dash to wiggle your steering wheel, then you probably have the fairly common failure of the electronic steering lock mechanism. You cannot install a used one. It must be new. These are a bit expensive and tough to get a hold of. But you can certainly get one still. If the vehicle won’t start, what you can do is open the drivers door and then keep cycling The ignition. After it does start, with it running ,open the LF door , remove the driver door switch for done light and unplug it. This will keep the steering lock from locking your steering again and it won’t have to reconnect the starter circuit. This is the cheat fix. You will lose auto dome light from driver door.
Thanks for the advice. I’ll try that.old tech wrote: ↑Mon Jul 11, 2022 6:44 am If you are experiencing the no crank situation and a message appears on the dash to wiggle your steering wheel, then you probably have the fairly common failure of the electronic steering lock mechanism. You cannot install a used one. It must be new. These are a bit expensive and tough to get a hold of. But you can certainly get one still. If the vehicle won’t start, what you can do is open the drivers door and then keep cycling The ignition. After it does start, with it running ,open the LF door , remove the driver door switch for done light and unplug it. This will keep the steering lock from locking your steering again and it won’t have to reconnect the starter circuit. This is the cheat fix. You will lose auto dome light from driver door.
But I want to clarify what is LF actually. Is it Left Front door? I’m from Malaysia, my driver seat is on the right side.
And do you mean auto dome light will not auto turn on when driver door is open? This should be ok.
I have the same issue with my one i can hear the crank but it doesn’t start and i have to keep on trying and it will do. I get it checked in the dealership and they changed the crankshaft or cam shaft sensor but still the same problem.
Has your fixed already? If you have fixed what was the issue please help
