I'm a bit lost if I have to order the part N°32 or 33
(even the 30-31 If I understand this one gets corroded as well)
The shock mount that commonly corrodes and breaks is no. 32. If the 2 bolts securing this (no.35) break off , then it would be easiest to change bracket no. 30-31 Not cheap. If a noise over bumps is what you are going after , Check stabilizer bar to frame bushings and bottom shock bolts first.pix74 wrote: ↑Mon May 17, 2021 7:44 pm I suddenly have a doubt regarding what I ordered, can you please advise me : I ordered the plastic bushing (black part on the picture above), when you are all talking about the rear shock mount are you talking about these plastic bushing or the metallic part below this bushing ?
