Speaker static
Ive been experiencing worsening speaker static / popping noise, which seems to correlate with when i apply the brake. Ive found it to be more prominent when i first start the car, and also perhaps after rain. Coming from only the left passenger door speaker. This happens even when no source is selected or radio off. Anyone experienced this?
2011 Kizash SLS AWD
SLS = RF audio with amplifier in the boot/ trunk?
It could be noise (voltage spikes) from your alternator when it's charging the battery. The battery would be at it's lowest voltage just after starting, so maximum drain on the alternator. When it's fully charged the battery would act like a filter and reduce the spikes from the alternator.
try adding a ground loop isolator. They're about 10 bucks at Radio Shack so if it didn't work, you wouldn't be out much...
This does sound like a grounding issue. Are you still under warranty?
Hmm. Is there a way you can record the sound using a small video camera pointed at the speaker? Then, I'd give them the video clip and tell them to check out all grounds that could be an issue.ipaqxman wrote:I am. But as usual, everytime I bring the car to the dealer they cannot replicate the issue
The other thing I'd do is check the service manual to find out where the grounds that may be related to this issue are and check them myself.
Wow, just wow. Morons. How can hearing a recording of it for preliminary diagnosis be any different than when it actually happens?
Stay away from those clowns. Just break open the Factory Service Manual and see what you can do on your own. And we'll help!
