Gear shift linkage cable
Mokachino
Hey guys,
Recently replaced the clutch on my 6spd manual 2011 Kizash. Prick of a job by the way, while getting the gear box out I had to remove the gear shift cable from the gearbox. It has a ridiculous sealed black plastic/rubber bush on it that holds it all in place. I didn't have the tool to remove it so we ended up breaking it off.
My question is does anyone know if the bush that connects the linkage to the gearbox is replaceable and if so do you know the part number because for the life of me I cannot find it.
The part number of the whole cable is 2830057L00
I've looked around as many wreckers as I can find and none of them seem to stock kizashis or that part
Try Megazip.net. They source parts from Japan.
https://www.megazip.net/zapchasti-dlya- ... ol-3790245
rossirob73
Those kizashi manuals are hard to come by. Wish mine was manual.
rossirob73
How did you go with the linkages.
What did you end up doing in the end to fix the problem.
Raggedyman78
Has anyone had any luck finding these more recently? My son is currently driving a 2010 Kizashi with a 6-speed manual that just won't seat into reverse anymore. Figured replacing the cables wouldn't be a bad idea, but I can't find them anywhere and even on the official parts pages it looks like they discontinued the product. Any thoughts on either a makeshift solution or custom fabricated part? Thanks.
