Trunk release
Mecton55
Hi,
my car trunk does not open when using the key or the button inside the cabin. The only way to open it is to reach the handle from inside the trunk.
Is anyone here had the same problem and where should i look first?
Hope my english is not to bad. Thanks
nytq
Verify the trunk lid lock switch is not on in the glove box.
Trunk Lid Lock Switch.pdf
(33.9 KiB) Downloaded 670 times
Mecton55
Thank you nytq!!
I did not knew about this lock. My son just confessed it was him who had played in the glove box!
You saved me alot of time!
nytq
Your welcome. Glad it was an easy fix.
Czer
Thank you for this! I missed the switch and found the info AFTER I had ordered a replacement latch. FYI the same trunk latch is used by Toyota for the Yaris of the same year. It’s available on Amazon for $30 cdn instead of $150 usd and out of stock or back ordered oem.
Czer wrote:Thank you for this! I missed the switch and found the info AFTER I had ordered a replacement latch. FYI the same trunk latch is used by Toyota for the Yaris of the same year. It’s available on Amazon for $30 cdn instead of $150 usd and out of stock or back ordered oem.
Interesting... The Kizashi also uses the same fog light as the Yaris of the same model years. I wonder what other minor parts they share.
Fog lights are the same as Camry too.
