CVT appears to have bit it at 165k miles - expected lifespan?
Are they just playing Parts Darts?
What do the starter and the transmission have in common? I'm failing to see the logic here, what is the symptom.
Next they'll replace the wiper motor to solve the issue.
2010 Kizashi GTS FWD
- ProMarinero
Sorry I haven't replied. The used CVT finally arrived last Tuesday. I plan to install it next weekend. It's a 30,000 mile unit and they also included (forgot to remove) the transfer case, so that was a nice bonus. I am also planning to replace the water pump, timing chain tensioner and guides at the same time while the engine is out. I will take some pics for reference should anyone else need them.
As far as the Excursion goes.... maybe I shouldn't be doing this CVT. I blew up my own engine installing a front sway bar.
When I put the new thicker aftermarket unit on, I was in a hurry and zipped off the old one without really looking at it. When I went to install the new one, I didn't know whether the bend in it went up or down. I checked the instructions which were useless. The pictures were horrible and the text made no mention of orientation. After looking on the OEM Ford diagram (up) and checking the wear pattern on the old bar (up) I decided to install it up. When I set the car back down, the bar was very close to the differential but I thought that must be the way and hustled out. After driving around for two months, the bar flex slowly pushed the oil pan in until it was against the oil pump screen. Yep - it was an $8000 swaybar.
When the mechanic who was doing the work showed me I couldn't believe it. I asked him of any good places to donate my tools since I shouldn't be using them anymore.
He told me it happens at some point to everyone, but I'm not convinced it's quite on that scale of ineptitude. ![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
![Facepalm :facepalm:](./images/smilies/icon_facepalm.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
- ProMarinero
SUCCESS!!! Finally got it in this weekend and fixed a couple little issues today. We’re back at 166k with a 30k transmission. This thing should run to 300k now!
It would have been done a couple weeks earlier but I found that the best place to order seals is OEM because every one listed elsewhere was the wrong size and NOK seals do not cross. Anyway, I’ll post more details later but I just wanted to report that it worked.
Congrats. Keep us posted on the details and how it holds up.ProMarinero wrote:SUCCESS!!! Finally got it in this weekend and fixed a couple little issues today. We’re back at 166k with a 30k transmission. This thing should run to 300k now!It would have been done a couple weeks earlier but I found that the best place to order seals is OEM because every one listed elsewhere was the wrong size and NOK seals do not cross. Anyway, I’ll post more details later but I just wanted to report that it worked.
How’d the Excursion go? We may as well get google search hits on that vehicle to send people here. I hope it’s not a 6.0 ![Neutral :|](./images/smilies/icon_neutral.gif)
- ProMarinero
Stand by.... I'm on my third driver's side axle seal and it's leaking too. Hoping it's not the diff bearing in the unit I received. Once this is done I will post the whole thing.
The Excursion got a remanufactured V10 to replace my f-up. That is running great and it should - it was only $8,000 after labor and everything else.
Needless to say I will be installing a real, actual oil pressure gauge and not relying on Ford's stupid on/off gauge that goes from the middle to low at 7 psi.
You’re right on the stupid pressure gauge. I read somewhere that years ago Ford switched to a gauge that only had 3 readings. None, normal and high. What a great idea
I have a 6.7 and all it has is a dummy light. $25k motor and no pressure gauge. I want to install one but need to do some research to see if there’s a place to do it easily.
I don’t know much about those v-10s other then the early models liked to spit out spark plugs.
![Sad :(](./images/smilies/icon_e_sad.gif)
