Whinning Noise - CVT?
- FrankoLaMoya
I have been experiencing the same whining at about 3500-4000 rpm after I remove my feet from the pedal after an acceleration... since I had it. I changed the transmission fluid (CVT) at 50 000 km (Canadian). The mechanic said ''it is not normal'', but never been able to pin point the issue. I am currently at 63 000 km and it is still doing the same whining sound without causing any issues... If I just cruise I usually do not hear it, but when I press the gas pedal a little harder and release it.. whining time. lol I don't think you need to worry too much about it. It is annoying, but not necessarily an issue (so far anyway).
Hello,
My name is Mario and I'm from Germany and I'm in German Kizashi Forum represented.
I drive a Suzuki Kizashi 4x4 CVT and showed exactly the same problems as in the videos.
Have now gone 90 000 km offering since 7000 km is the sound there.
What can you do about it?
Did any information for me?
Thank you so much
Mario
Thank you so much
Mario
here we go .This is my first post .I have a 2012 Kizashi GTS have 80000 when the power train is hot it starts to whine on exceleration.in addition i have lost power the car will not go over 2500rpm and does not shift.I have stopped and turned off car and let cool.It will act normal but once it gets hot the same issue.This does not occur all the time but has become more frequent.Has anyone had this issue and is there a dealership that knows how to deal with it?
Hello,
I have the noise constantly since 12,000 km.
As soon as he is warm the noise comes with 3000 min1.
Nobody knows what it should be.
If a tech has said that it's not normal, then you should have it checked at a Suzuki service center and have them open a ticket with Suzuki.
I had a noise in my 2011 SLS FWD (76K miles) that I had for a long time and progressively got louder but over 20K miles. I actually drove some used ones just to verify that it was not normal. It wasn't really a whine, but more a groan the changed pitch with the speed of the car. It only was exhibited when coasting or light acceleration up. Went away if I shifted into neutral. The tech drove the car and said it was definitely not normal. The service center here opened a ticket with Suzuki and a week later I was driving with a new transmission and no noise. Cost to me? $0 and a free loaner while the work was being done.
But what is the problem with the transmission?
Where does the sound from the transmission?
Mario
Mario
If the sound is actually in the transmission and not some other part of the drive train, that's all they need to know. There are no serviceable parts in the transmission other than to drop the pan and change the fluid and filter. There are no adjustments or parts that they can replace as far as I know. It's a swap with a new transmission. If you're dealing with a non-Suzuki service center and the vehicle is still under warranty, get it to an authorized service center and have them deal with it.
Sorry to bump an old topic, but I figured this would be the best place to ask.
I recently bought a 2013 Kizashi with 58K miles. Runs and drives great, but I've noticed a slight whine after the car warms up for awhile (around 30+ minutes into a drive). It seems to be RPM dependent, and it occurs in any gear (park, reverse, drive, neutral).
It sounds like the "CVT whine," albeit a bit quieter, but since it also occurs in neutral, I'm not sure. Any ideas?
I have a 2010 with 123K and it does the same thing. Check the transmission fluid. Change if it’s bad. I don’t think it’s anything to worry about. Ive dropped the pan on mine twice and changed the screen. I’ve also replaced the satellite filter and flushed the whole transmission once.Mike_ wrote:It sounds like the "CVT whine," albeit a bit quieter, but since it also occurs in neutral, I'm not sure. Any ideas?
When you say it does it in neutral that sounds like more of an engine noise. However I am not a mechanic and I don’t know how the CVT works in neutral. But I would assume the drive belt is disengaged. So the CVT whine shouldn’t be present.
2010 Kizashi GTS FWD
The whine is most likely the hydro pump. The whine changes with temp increase because the fluid it's pumping has changed. AFAIK, the pump pumps fluid in neutral as long as engine is running.
sold)
