Problems with TPMS on 2010 Kizashi SLS
RECMAN0917
Having problems with TPMS on my 2010 Kizashi SLS. Have aftermarket wheels and tires. Pressure is good and sensors were checked out. Dashboard indicator still won't go out. Any suggestions?
Where did you get the wheels and sensors? Are the sensors factory or aftermarket?
Could test the one for 23 bucks from rockauto. I know when the kizashi first came out they TPMS were stupid expensive for each tire.
The factory ones still are at around $160+ each. But from what I know about aftermarket auto parts (I used to be a radiator distributor), there can be a significant difference in quality when there's such a big price difference.
RECMAN0917
Had aftermarket sensors Got dealer ones pretty pricey around $175.00
You need to relearn the sensors into the car. I did this myself when I made myself a set of snow tires for the winter using a tool, but I have a theory on how to do it without the tool if you'd like to try it.
Theory on relearning the sensors without a tool confirmed!
http://www.kizashiclub.com/forum/viewto ... 237#p25237
peezi
Don't waste your money on Stealership sensors, I got 4 installed for $190 including rebalancing @ Discount Tire and they said come in anytime and the will rotate my tires for free until I need new ones since I had work done there...
John PZ
2010 Suzuki Kizashi SLS AWD
peezi wrote:Don't waste your money on Stealership sensors, I got 4 installed for $190 including rebalancing @ Discount Tire and they said come in anytime and the will rotate my tires for free until I need new ones since I had work done there...
You can get a full set of used Suzuki sensors for under $100. Aftermarket ones are much cheaper than the factory ones and they're virtually idenical if they're made by VDO (since they make the factory ones for Suzuki).
peezi
Why would you want to buy used sensors and then have to deal with installing them yourself? Just go to Discount Tire and they will do the whole thing in 45 minutes. Its worth the extra $90 dollars and if something goes wrong they will resolve the problem for you. Plus, I think those things have batteries, so used = shorter life span...
John PZ
