2011 Kizashi Bluetooth features?
mcprodriver
I am able to make calls via bluetooth. Does the 2011 have the ability to stream audio as well?
Thanks in advance.
BLyons
Yes it does. You have to set up your device for audio though instead of phone only.
Black 2011 Sport SLS AWD
mcprodriver
BLyons wrote:Yes it does. You have to set up your device for audio though instead of phone only.
So, this is handled from the phone end, correct? Anything I need to do from the car end of things?
Marcov71
I figured mine out accidentally. I have to press CD button. But, it wont work if you have a CD inserted. Take the CD out.
Orange County/Brooklyn NY
mcprodriver
Marcov71 wrote:I figured mine out accidentally. I have to press CD button. But, it wont work if you have a CD inserted. Take the CD out.
So, press the CD button to enable music streaming after bluetooth voice calling is already active?
Just need clarification.
Marcov71
Pair your phone with the car. Once paired, you should be able to make/receive calls. Go on phone select Pandora or whatever you want to listen to an press the CD button.It will start transmitting.
mcprodriver
Marcov71 wrote:Pair your phone with the car. Once paired, you should be able to make/receive calls. Go on phone select Pandora or whatever you want to listen to an press the CD button.It will start transmitting.
Thank you very much for the info.
BLyons
When you pair the phone, you can choose phone only or internal audio. Choose internal audio and you will have both phone and streaming. It does still work even if there is a CD in, you just push the CD button again to cycle between bluetooth and the CD player.
