Hi all, I've actually had one of the little "run lamps" go out on my Kizashi. It's the little, "other" bulb in the headlight that isn't low-beam, high-beam, or turn indicator. The Suzuki part number is "0947112216 - Run lamp", but does anyone know the normal part number? I want to change it the next time I have to go through the minor hell that it is to change headlight bulbs in this otherwise fine vehicle. Also, I sorta looked last time I was in there at how to do this replacement and it didn't look straightforward, it's in an awkward spot in the headlight assembly, so has anyone done this and any tips??
Here's a link to the part & schematic - https://suzukicarparts.com/parts/2010/S ... eid=214820
Thanks!
Normal bulb part number for "run lamp"??
They're also called position bulbs. Any T10 or 194 bulb should fit. You'll have to pull the high beam out, then you pull on the cable running to the bulb. If there's any sort of release, I don't know about it, I just ended up pulling hard on it.
Black 2011 Sport SLS AWD
Yup. Just pull on the harness wire because there is no way your fingers can reach the housing for the position bulb.
I changed mine out and put LEDs in to match my white HID low beams. Here's a write-up on it that may help you.
http://www.kizashiclub.com/forum/viewto ... =28&t=2141
