My son's 2011 Kiz won't shut off :-(
AudreySchrader
This problem just recently started, the car starts great but will not shut off, it's gotten to the point the fuse needs to be pulled out! Scary thought, help! :o
Try pressing and holding the Start button for at least 5 seconds to see if this turns the engine off. Regardless, it sounds like the button or related starting components are malfunctioning and they should be replaced. Is the car still under warranty?
cobymark
Did you go to your dealer? Check all the fuses and relays also.
