Flasher
david.blevins
Where can I find the fuse for turn signal? I couldn't find them. Is it somewhere else beside the hood and driver?
david.blevins wrote:Where can I find the fuse for turn signal? I couldn't find them. Is it somewhere else beside the hood and driver?
I don't think there is such as fuse. What's the issue? Is more than one bulb out? Did you check the connectors and wiring to the bulbs?
According to the owner's manual, it on the inside. Does your hazard work? That's fuse 22 red, 10 amp. But I don't see a listing for turn signals. That is rather strange. Do you have the owner's manual? Maybe there's a fuse in there that's not listed in the manual.
david.blevins
My mistake, I mean the hazard fuse. I was planning on to use LED lights for turn signals and don't want to use load resistors.
