Hi
Whenever I reverse the car or go over bumps I hear a clunk sound in the rear left hand passenger side like something is loose in the passenger rear side...i initially thought I left some thing metallic in the trunk of the car...it's becoming a pain in the you know where literally... what could it be..helpppppp
P.s- it's sounds like it's just coming from the left rear side
Clunk/banging noise while reversing and over bumps in the passenger rear side
Check your suspension components and stabilizer (sway bar). Look to see if parts are cracked or broken such as the shock mount, sway bar bushings, or linkage for the sway bar. Blown shocks often make a creaking noise rather than a clunking one so you'll want to check for loose or broken parts.
Yes, the earlier models had a faulty rear bump stopper that didn't drain moisture well. This caused the shock below it to corrode early and fail. However, mine exhibited creaking, not banging or heavy clunking. Both of my rears were bad but perhaps not fully gone. Thankfully, it was covered under warranty at the time and I also got the revised bump stoppers. I've had no issues with the suspension since and it's been at least 3.5 years.motosonic wrote:I had the same thing. Rear passenger side. It was the shock and it was totally blown out and leaking. From what I have heard/can tell, this is a common issue with this car.
- Speed_Racer
It's common enough there's a TSB for it. Might be worth checking it out, if it was caused by the bump stop they'll replace it + the shock absorber for you. Here's the TSB form --motosonic wrote:I had the same thing. Rear passenger side. It was the shock and it was totally blown out and leaking. From what I have heard/can tell, this is a common issue with this car.
- TSB_Squeaky Shock.pdf
- (703.09 KiB) Downloaded 407 times
This isn't a safety recall, so only if the car is still within the 3/36k bumper-to-bumper warranty period. Which is probably not very likely.Speed_Racer wrote: It's common enough there's a TSB for it. Might be worth checking it out, if it was caused by the bump stop they'll replace it + the shock absorber for you.
- Speed_Racer
Good call, you're right. I didn't realize how long ago I had mine replaced and that it was still under the 3/36 at the time.Ronzuki wrote: This isn't a safety recall, so only if the car is still within the 3/36k bumper-to-bumper warranty period. Which is probably not very likely.
