Vibration over 55 MPH
I just got a 2012 Suzuki Kizashi Sport SLS AWD with 80,000 miles. When I drive over 55 MPH, there is a very noticeable vibration throughout the steering wheel, dashboard, and under my feet. It seems to mostly go away when I go around bends and corners at the same speed, or while I am going up a hill sometimes. Tires were replaced by last owner around 55,000 miles. They seem to look good but that doesn't mean a lot. Just passed inspection, etc. two days ago so wondering if I should get an alignment or start looking at new tires. Any help would be appreciated.
I agree with the suggestions of the others. For the vibration at speed, check wheel balance. Also have suspension inspected. Suspension issues can also cause uneven tire wear such as tire cupping which causes noise and vibrations while driving.
As for idle, clean and replace parts. At 80K, it's time for new spark plugs. Check the throttle body and check PCV valve.
